									Setting multiple pins as OUTPUT - Programming				            </title>
            <link>https://forum.etechnophiles.com/arduino-programming/setting-multiple-pins-as-output/</link>
            <lastBuildDate>Sun, 13 Sep 2026 01:38:57 +0000</lastBuildDate>
                        <title>Answer to: Setting multiple pins as OUTPUT</title>
                        <link>https://forum.etechnophiles.com/arduino-programming/setting-multiple-pins-as-output/#post-129</link>
                        <pubDate>Thu, 26 Sep 2024 05:09:20 +0000</pubDate>
                        <description><![CDATA[Here&#039;s an example using a for loop to configure 8 digital pins (from pin 2 to pin 9) as outputs:
int ledPins[] = {2, 3, 4, 5, 6, 7, 8, 9}; // Array of pin numbers
  for (...]]></description>
                        <content:encoded><![CDATA[<p>Here's an example using a <code>for</code> loop to configure 8 digital pins (from pin 2 to pin 9) as outputs:</p>
<pre contenteditable="false">int ledPins[] = {2, 3, 4, 5, 6, 7, 8, 9}; // Array of pin numbers
  for (int i = 0; i &lt; 8; i++) {
    pinMode(ledPins, OUTPUT); // Set each pin as an output
  // Your code to control LEDs goes here
<p>If the pins are not in a series, you can still use an array:</p>
<pre contenteditable="false">int ledPins[] = {2, 5, 7, 8, 10, 12, 13, A0}; // Array of specific pin numbers
    pinMode(ledPins, OUTPUT); // Set each specified pin as an output
						                            <category domain="https://forum.etechnophiles.com/arduino-programming/">Programming</category>                        <dc:creator>nathan</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino-programming/setting-multiple-pins-as-output/#post-129</guid>
                        <title>RE: Setting multiple pins as OUTPUT</title>
                        <link>https://forum.etechnophiles.com/arduino-programming/setting-multiple-pins-as-output/#post-108</link>
                        <pubDate>Fri, 06 Sep 2024 06:22:04 +0000</pubDate>
                        <description><![CDATA[@ankunegi Thank you. You are a life saver!!]]></description>
                        <content:encoded><![CDATA[@ankunegi Thank you. You are a life saver!!]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/arduino-programming/">Programming</category>                        <dc:creator>Mehjabeen</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino-programming/setting-multiple-pins-as-output/#post-108</guid>
                        <link>https://forum.etechnophiles.com/arduino-programming/setting-multiple-pins-as-output/#post-104</link>
                        <pubDate>Thu, 29 Aug 2024 07:23:48 +0000</pubDate>
                        <description><![CDATA[For loop will do the job if the pins are in series:
for (int i = 2; i &lt;= 9; i++) { 
pinMode(i, OUTPUT);
If pins are random, use an array like this:
int buttons[]={2,4,5,8,10,13};...]]></description>
                        <content:encoded><![CDATA[<p>For loop will do the job if the pins are in series:</p>
<pre contenteditable="false">for (int i = 2; i &lt;= 9; i++) { 
pinMode(i, OUTPUT);
<p>If pins are random, use an array like this:</p>
<pre contenteditable="false">int buttons[]={2,4,5,8,10,13};
for(int i:buttons){
pinMode(i, OUTPUT);
}</pre>
						                            <category domain="https://forum.etechnophiles.com/arduino-programming/">Programming</category>                        <dc:creator>Admin</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino-programming/setting-multiple-pins-as-output/#post-104</guid>
                        <link>https://forum.etechnophiles.com/arduino-programming/setting-multiple-pins-as-output/#post-103</link>
                        <pubDate>Thu, 29 Aug 2024 07:21:37 +0000</pubDate>
                        <description><![CDATA[@jignesh You can use an array: int buttons[]={2,4,5,8,10,13,}; for(int i:buttons){ pinMode(i, OUTPUT); }]]></description>
                        <content:encoded><![CDATA[@jignesh You can use an array: int buttons[]={2,4,5,8,10,13,}; for(int i:buttons){ pinMode(i, OUTPUT); }]]></content:encoded>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino-programming/setting-multiple-pins-as-output/#post-103</guid>
                        <link>https://forum.etechnophiles.com/arduino-programming/setting-multiple-pins-as-output/#post-22</link>
                        <pubDate>Fri, 10 May 2024 05:50:42 +0000</pubDate>
                        <description><![CDATA[@jignesh What if the pins are not in series? For example 2,4,5,8,10,13.]]></description>
                        <content:encoded><![CDATA[@jignesh What if the pins are not in series? For example 2,4,5,8,10,13.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino-programming/setting-multiple-pins-as-output/#post-22</guid>
                        <link>https://forum.etechnophiles.com/arduino-programming/setting-multiple-pins-as-output/#post-13</link>
                        <pubDate>Fri, 03 May 2024 07:42:44 +0000</pubDate>
                        <description><![CDATA[You can use for loop for this; here&#039;s how
pinMode(i, OUTPUT);
This loop goes from pin 2 to 9 and sets each pin as OUTPUT. .]]></description>
                        <content:encoded><![CDATA[<p>You can use for loop for this; here's how<br /><br /><br /></p>
pinMode(i, OUTPUT);
}</pre>
<p><br /><br />This loop goes from pin 2 to 9 and sets each pin as OUTPUT. <br /><br /><br /><br /><br />.<br /><br /></p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/arduino-programming/">Programming</category>                        <dc:creator>Jignesh</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino-programming/setting-multiple-pins-as-output/#post-13</guid>
                        <title>Setting multiple pins as OUTPUT</title>
                        <link>https://forum.etechnophiles.com/arduino-programming/setting-multiple-pins-as-output/#post-11</link>
                        <pubDate>Thu, 02 May 2024 12:38:59 +0000</pubDate>
                        <description><![CDATA[Hi,
I am using 8 digital pins to control the 8 LEDs separately. Instead of writing &quot;pinMode(pin,OUTPUT)&quot; for every other pin, is there any short method?]]></description>
                        <content:encoded><![CDATA[<p>Hi,</p>
<p>I am using 8 digital pins to control the 8 LEDs separately. Instead of writing "pinMode(pin,OUTPUT)" for every other pin, is there any short method?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino-programming/setting-multiple-pins-as-output/#post-11</guid>
