									Arduino Code Not Uploading – What Could Be the Issue? - Arduino				            </title>
            <link>https://forum.etechnophiles.com/arduino/arduino-code-not-uploading-what-could-be-the-issue/</link>
            <lastBuildDate>Sun, 12 Apr 2026 14:27:25 +0000</lastBuildDate>
                        <title>Answer to: Arduino Code Not Uploading – What Could Be the Issue?</title>
                        <link>https://forum.etechnophiles.com/arduino/arduino-code-not-uploading-what-could-be-the-issue/#post-491</link>
                        <pubDate>Tue, 24 Jun 2025 05:06:28 +0000</pubDate>
                        <description><![CDATA[This is a common issue, and it usually means the Arduino IDE is unable to communicate with your board during the upload process.
Here are several things you should check:1. Check Board Sele...]]></description>
                        <content:encoded><![CDATA[<p>This is a common issue, and it usually means the Arduino IDE is unable to communicate with your board during the upload process.</p>
<p>Here are several things you should check:<br /><br />1. Check Board Selection</p>
<p>Tools → Board – Make sure the correct board (e.g., Uno, Nano) is selected.<br /><br />2. Check Port</p>
<p>Tools → Port – Choose the correct COM port (replug board to see which one appears).<br /><br />3. Use a Proper USB Cable</p>
<p>Some cables are charge-only. Try a different one that supports data.<br /><br />4. Install Drivers</p>
<p>For clone boards (e.g., CH340), make sure USB drivers are installed.<br /><br />5. Disconnect from Pins 0 &amp; 1</p>
<p>Remove anything connected to RX (0) and TX (1) during upload.<br /><br />6. Try Reset</p>
<p>Press the Reset button just before or during upload (for older boards).<br /><br />7. Bootloader</p>
<p>If the board is new or a clone, it might not have a bootloader. You'll need to burn it using another Arduino.<br /><br /><br /></p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/arduino/">Arduino</category>                        <dc:creator>Deboojit</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino/arduino-code-not-uploading-what-could-be-the-issue/#post-491</guid>
                        <title>Arduino Code Not Uploading – What Could Be the Issue?</title>
                        <link>https://forum.etechnophiles.com/arduino/arduino-code-not-uploading-what-could-be-the-issue/#post-488</link>
                        <pubDate>Mon, 23 Jun 2025 04:49:34 +0000</pubDate>
                        <description><![CDATA[I&#039;m trying to upload a sketch to my Arduino board, but it keeps failing. I&#039;m using the Arduino IDE, and I’ve double-checked my code—it compiles fine. However, during upload, I get an error m...]]></description>
                        <content:encoded><![CDATA[<p>I'm trying to upload a sketch to my Arduino board, but it keeps failing. I'm using the Arduino IDE, and I’ve double-checked my code—it compiles fine. However, during upload, I get an error message like “avrdude: stk500_recv(): programmer is not responding” or “timeout communicating with programmer.”</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/arduino/">Arduino</category>                        <dc:creator>Zane_Tech</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino/arduino-code-not-uploading-what-could-be-the-issue/#post-488</guid>
