									Arduino UNO R4 Wi-Fi Project ideas! - Arduino				            </title>
            <link>https://forum.etechnophiles.com/arduino/arduino-uno-r4-wi-fi-project-ideas/</link>
            <lastBuildDate>Sun, 12 Apr 2026 16:06:48 +0000</lastBuildDate>
                        <title>Answer to: Arduino UNO R4 Wi-Fi Project ideas!</title>
                        <link>https://forum.etechnophiles.com/arduino/arduino-uno-r4-wi-fi-project-ideas/#post-359</link>
                        <pubDate>Mon, 17 Feb 2025 09:25:39 +0000</pubDate>
                        <description><![CDATA[Since you’re eager to explore, here are some Arduino UNO R4 WiFi project ideas that take full advantage of its capabilities:
Beginner-Friendly Projects 
1. Wi-Fi Weather Dashboard – Connec...]]></description>
                        <content:encoded><![CDATA[<p>Since you’re eager to explore, here are some Arduino UNO R4 WiFi project ideas that take full advantage of its capabilities:</p>
<h3><strong>Beginner-Friendly Projects</strong> </h3>
<p>1. <strong>Wi-Fi Weather Dashboard</strong> – Connect a <strong>DHT22</strong> or <strong>BMP280</strong> sensor to measure temperature, humidity, and pressure, then display the data on a web interface.<br />2. <strong>Remote-Controlled LEDs</strong> – Create a simple <strong>web-based LED controller</strong> using the board’s Wi-Fi, allowing you to turn LEDs on/off from your phone.<br />3. <strong>Wireless Sensor Hub</strong> – Connect multiple <strong>sensors (LDR, temperature, gas)</strong> and send the data wirelessly to another device using <strong>MQTT</strong>.</p>
<h3><strong>Intermediate Projects</strong> </h3>
<p>4. <strong>IoT-Based Smart Lock</strong> – Use an <strong>RFID module</strong> or <strong>fingerprint sensor</strong> to control a <strong>servo-motorized lock</strong>, with access logs stored on a cloud database.<br />5. <strong>Real-Time Data Logger</strong> – Log sensor readings onto an <strong>SD card</strong> and simultaneously send them to <strong>Google Sheets or Thingspeak</strong> for remote tracking.<br />6. <strong>Smart Water Level Monitor</strong> – Attach <strong>ultrasonic sensors</strong> to a water tank and get alerts via <strong>Telegram or email</strong> when water levels drop.</p>
<h3><strong>Advanced Projects</strong> </h3>
<p>7. <strong>Home Automation with Voice Control</strong> – Integrate with <strong>Google Assistant or Alexa</strong> using <strong>ESP8266 API</strong> to control appliances via voice commands.<br />8. <strong>Gesture-Controlled IoT Device</strong> – Pair a <strong>gesture sensor</strong> with Wi-Fi connectivity to control appliances or robots using simple hand movements.<br />9. <strong>AI-Based Motion Detection</strong> – Use <strong>Edge Impulse</strong> to train an AI model that detects movement and triggers an alert, ideal for a DIY security system.<br />10. <strong>Arduino-Powered IoT Dashboard</strong> – Build a complete web-based dashboard to control and monitor multiple devices in real time.</p>
<p>With the UNO R4 WiFi, you can easily experiment with web-based control, IoT data visualization, and cloud integrations—no need for extra shields! What kind of project excites you the most? Let’s get building! </p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/arduino/">Arduino</category>                        <dc:creator>Admin</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino/arduino-uno-r4-wi-fi-project-ideas/#post-359</guid>
                        <title>RE: Arduino UNO R4 Wi-Fi Project ideas!</title>
                        <link>https://forum.etechnophiles.com/arduino/arduino-uno-r4-wi-fi-project-ideas/#post-303</link>
                        <pubDate>Fri, 10 Jan 2025 10:55:55 +0000</pubDate>
                        <description><![CDATA[@yvette Thanks for sharing this list! The Weather Station Using Visuino project sounds like a great way to dive into IoT and sensor integration. I’ve never used Visuino before....was it easy...]]></description>
                        <content:encoded><![CDATA[@yvette Thanks for sharing this list! The Weather Station Using Visuino project sounds like a great way to dive into IoT and sensor integration. I’ve never used Visuino before....was it easy to get started with? I might give this one a shot since I have some sensors lying around.]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/arduino/">Arduino</category>                        <dc:creator>Daniel</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino/arduino-uno-r4-wi-fi-project-ideas/#post-303</guid>
                        <link>https://forum.etechnophiles.com/arduino/arduino-uno-r4-wi-fi-project-ideas/#post-199</link>
                        <pubDate>Sat, 09 Nov 2024 05:14:45 +0000</pubDate>
                        <description><![CDATA[Here is the list of UNO R4 WiFi projects I found during my research:
1. Weather Station Using Arduino UNO R4 WiFi &amp; VisuinoBuild a weather station to monitor temperature, humidity, and ...]]></description>
                        <content:encoded><![CDATA[<p>Here is the list of UNO R4 WiFi projects I found during my research:</p>
<p><strong>1. Weather Station Using Arduino UNO R4 WiFi &amp; Visuino</strong><br />Build a weather station to monitor temperature, humidity, and pressure using sensors. The data is displayed and updated in real time using Visuino software.<br /><strong>Project Link:</strong> <a href="https://projecthub.arduino.cc/frtek/weather-station-using-arduino-uno-r4-wifi-visuino-a1558e" target="_new" rel="noopener"><span>Weather</span><span> Station</span><span> Project</span></a></p>
<p><strong>2. Arduino UNO R4 WiFi Experiments</strong><br />Explore multiple small projects to familiarize yourself with the UNO R4 WiFi, including controlling the onboard LED matrix and creating simple WiFi apps.<br /><strong>Project Link:</strong> <a href="https://www.instructables.com/Arduino-UNO-R4-WiFi-Experiments/" target="_new" rel="noopener"><span>UNO</span><span> R4</span><span> WiFi</span><span> Experiments</span></a></p>
<p><strong>3. Home Automation with Web Server</strong><br />Set up a home automation system using a local web server hosted on the Arduino UNO R4 WiFi. Control home appliances remotely without relying on third-party IoT platforms.<br /><strong>Project Link:</strong> <a href="https://www.instructables.com/Arduino-UNO-R4-WIFI-Web-Server-Based-Home-Automati/" target="_new" rel="noopener"><span>Home</span><span> Automation</span><span> System</span></a></p>
<p><strong>4. LED Matrix Animations</strong><br />Learn how to program the built-in 12x8 LED matrix on the UNO R4 WiFi to display custom animations and graphics. A great project for beginners to practice coding and LED control.<br /><strong>Project Link:</strong> <a href="https://www.hackster.io/glowascii/programming-the-arduino-uno-r4-wifi-s-led-matrix-2f9c8d" target="_new" rel="noopener"><span>LED</span><span> Matrix</span><span> Programming</span></a></p>
<p><strong>5. Smartphone-like Device with Apps</strong><br />Transform the Arduino UNO R4 WiFi into a smartphone-like device with multiple apps, a keyboard, and cloud sync. An innovative project showcasing the board's capabilities.<br /><strong>Project Link:</strong> <a href="https://projecthub.arduino.cc/AdityaAg/create-a-smartphone-like-device-with-the-arduino-uno-r4-wifi-multiple-apps-keyboard-dynamic-wifi-cloud-sync-95ccec" target="_new" rel="noopener"><span>Smartphone</span><span>-like</span><span> Device</span><span> Project</span></a></p>
<p><strong>6. SparkFun Qwiic Kit Integration</strong><br />Connect various sensors and components using the SparkFun Qwiic Kit with the Arduino UNO R4 WiFi. This guide is ideal for experimenting with multiple peripherals.<br /><strong>Project Link:</strong> <a href="https://learn.sparkfun.com/tutorials/sparkfun-arduino-uno-r4-wifi-qwiic-kit-hookup-guide/all" target="_new" rel="noopener"><span>SparkFun</span><span> Qwiic</span><span> Kit</span><span> Guide</span></a></p>
<p>P.S.:  I tried some of these not all.</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/arduino/">Arduino</category>                        <dc:creator>Yvette</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino/arduino-uno-r4-wi-fi-project-ideas/#post-199</guid>
                        <link>https://forum.etechnophiles.com/arduino/arduino-uno-r4-wi-fi-project-ideas/#post-168</link>
                        <pubDate>Fri, 18 Oct 2024 05:06:38 +0000</pubDate>
                        <description><![CDATA[UNO R4 WiFi has a built-in ESP32, so treat it as an ESP32 board. Whatever you can do using an ESP, you can do using UNO R4, even more. There&#039;s a catch though, finding appropriate libraries i...]]></description>
                        <content:encoded><![CDATA[<p>UNO R4 WiFi has a built-in ESP32, so treat it as an ESP32 board. Whatever you can do using an ESP, you can do using UNO R4, even more. There's a catch though, finding appropriate libraries is very difficult since its a new board.</p>
<p>Here are some UNO R4 WiFi project ideas:</p>
<li>Control lights, fans, or other home appliances through Wi-Fi using the board and relays.</li>
<li>Build a system to monitor air quality (e.g., CO2 levels, particulate matter). The UNO can send data to the cloud or a local display.</li>
<li>Create an automated irrigation system using soil moisture sensors to trigger water pumps based on soil conditions. You can control the system remotely using Wi-Fi.</li>
<li>Build a robot that can be controlled via a smartphone or web browser.</li>
<li>Build a smart doorbell that sends a notification or plays a sound on your phone when someone presses it.</li>
<li>Use a PIR sensor to detect the presence. You can send an automated email once someone is detected.</li>
<p>All these projects are easy to build using the Arduino IoT cloud with the board. Learn how to get started with the <a href="https://www.etechnophiles.com/arduino-iot-cloud-tutorial/" target="_blank" rel="noopener">Arduino IoT cloud tutorial</a> here.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino/arduino-uno-r4-wi-fi-project-ideas/#post-168</guid>
                        <link>https://forum.etechnophiles.com/arduino/arduino-uno-r4-wi-fi-project-ideas/#post-158</link>
                        <pubDate>Wed, 09 Oct 2024 04:45:14 +0000</pubDate>
                        <description><![CDATA[There are a lot of ideas you can implement with the Arduino UNO R4 Wifi, depending on what you want to achieve. However, I have done a few projects that you can also try, ranging from beginn...]]></description>
                        <content:encoded><![CDATA[<p>There are a lot of ideas you can implement with the Arduino UNO R4 Wifi, depending on what you want to achieve. However, I have done a few projects that you can also try, ranging from beginner to advanced levels:</p>
<li>Home Automation System</li>
<li>Smart Door Lock</li>
<li>IoT-Based Weather Station</li>
<li>Wi-Fi-Controlled Robot</li>
<li>Smart Irrigation System</li>
<li>Wi-Fi-Enabled Data Logger</li>
<li>Real-Time Air Quality Monitoring System</li>
<li>Wi-Fi-Based Notification System</li>
</ul>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/arduino/">Arduino</category>                        <dc:creator>Amelia</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino/arduino-uno-r4-wi-fi-project-ideas/#post-158</guid>
                        <title>Arduino UNO R4 Wi-Fi Project ideas!</title>
                        <link>https://forum.etechnophiles.com/arduino/arduino-uno-r4-wi-fi-project-ideas/#post-153</link>
                        <pubDate>Fri, 04 Oct 2024 12:01:27 +0000</pubDate>
                        <description><![CDATA[Hi everyone, 
I recently received my first Arduino UNO R4 WiFi, and I am very excited to test its capabilities. I would love to explore some project ideas using this board. If you have any ...]]></description>
                        <content:encoded><![CDATA[<p>Hi everyone, </p>
<p>I recently received my first Arduino UNO R4 WiFi, and I am very excited to test its capabilities. I would love to explore some project ideas using this board. If you have any suggestions for interesting projects, whether they involve IoT applications, sensor integration, data logging, or interactive features, please share! </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino/arduino-uno-r4-wi-fi-project-ideas/#post-153</guid>
