									RS232 vs. UART – What’s the difference? - Arduino				            </title>
            <link>https://forum.etechnophiles.com/arduino/rs232-vs-uart-whats-the-difference/</link>
            <lastBuildDate>Sun, 12 Apr 2026 15:21:06 +0000</lastBuildDate>
                        <title>Answer to: RS232 vs. UART – What’s the difference?</title>
                        <link>https://forum.etechnophiles.com/arduino/rs232-vs-uart-whats-the-difference/#post-399</link>
                        <pubDate>Tue, 18 Mar 2025 04:56:41 +0000</pubDate>
                        <description><![CDATA[The following points highlight the major differences between UART and RS-232:
UART (Universal Asynchronous Receiver-Transmitter) is a hardware module responsible for serial communicatio...]]></description>
                        <content:encoded><![CDATA[<p data-start="0" data-end="79">The following points highlight the major differences between UART and RS-232:</p>
<ol data-start="81" data-end="858" data-is-only-node="" data-is-last-node="">
<li data-start="81" data-end="314">
<p data-start="84" data-end="314">UART (Universal Asynchronous Receiver-Transmitter) is a hardware module responsible for serial communication, whereas RS-232 is a communication standard that defines voltage levels and signaling for serial data exchange.</p>
<li data-start="316" data-end="492">
<p data-start="319" data-end="492">UART operates at TTL logic levels, typically 0V for LOW and 3.3V or 5V for HIGH, while RS-232 uses higher voltage levels, ranging from ±3V to ±15V.</p>
<li data-start="494" data-end="680">
<p data-start="497" data-end="680">UART manages data framing with start and stop bits, whereas RS-232 does not define framing but specifies the physical layer, including connectors and wiring.</p>
<li data-start="682" data-end="858" data-is-last-node="">
<p data-start="685" data-end="858" data-is-last-node="">Since RS-232 operates at different voltage levels, a level shifter like MAX232 is required to interface RS-232 signals with UART-based TTL logic devices.</p>
</ol>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/arduino/">Arduino</category>                        <dc:creator>Rashid</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino/rs232-vs-uart-whats-the-difference/#post-399</guid>
                        <title>RS232 vs. UART – What’s the difference?</title>
                        <link>https://forum.etechnophiles.com/arduino/rs232-vs-uart-whats-the-difference/#post-398</link>
                        <pubDate>Mon, 17 Mar 2025 07:04:04 +0000</pubDate>
                        <description><![CDATA[I know a little about RS232 and UART, and I understand that both are serial communication protocols. However, I’d like to understand them more broadly. Can anyone explain their key differenc...]]></description>
                        <content:encoded><![CDATA[<p>I know a little about RS232 and UART, and I understand that both are serial communication protocols. However, I’d like to understand them more broadly. Can anyone explain their key differences in terms of functionality and applications?</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/arduino/">Arduino</category>                        <dc:creator>Alfred Alonso</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/arduino/rs232-vs-uart-whats-the-difference/#post-398</guid>
