									What connector do I need? - Circuits and Projects				            </title>
            <link>https://forum.etechnophiles.com/basic-electronics-circuits-projects/what-connector-do-i-need/</link>
            <lastBuildDate>Sun, 13 Sep 2026 02:17:05 +0000</lastBuildDate>
                        <title>RE: What connector do I need?</title>
                        <link>https://forum.etechnophiles.com/basic-electronics-circuits-projects/what-connector-do-i-need/#post-267</link>
                        <pubDate>Fri, 20 Dec 2024 12:50:59 +0000</pubDate>
                        <description><![CDATA[@gpag Cool! I&#039;m glad this helped.]]></description>
                        <content:encoded><![CDATA[@gpag Cool! I'm glad this helped.]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/basic-electronics-circuits-projects/">Circuits and Projects</category>                        <dc:creator>Admin</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/basic-electronics-circuits-projects/what-connector-do-i-need/#post-267</guid>
                        <title>Answer to: What connector do I need?</title>
                        <link>https://forum.etechnophiles.com/basic-electronics-circuits-projects/what-connector-do-i-need/#post-264</link>
                        <pubDate>Thu, 19 Dec 2024 20:02:30 +0000</pubDate>
                        <description><![CDATA[Thank you. Just what I need.]]></description>
                        <content:encoded><![CDATA[<p>Thank you. Just what I need.</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/basic-electronics-circuits-projects/">Circuits and Projects</category>                        <dc:creator>GPag</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/basic-electronics-circuits-projects/what-connector-do-i-need/#post-264</guid>
                        <link>https://forum.etechnophiles.com/basic-electronics-circuits-projects/what-connector-do-i-need/#post-262</link>
                        <pubDate>Wed, 18 Dec 2024 05:48:29 +0000</pubDate>
                        <description><![CDATA[From the images you provided, the connector looks like a JST PH 2-pin connector:
Pin Count: Your connector has 2 pins.
Pitch (Pin Spacing): The spacing between the pins is likely 2.0 mm,...]]></description>
                        <content:encoded><![CDATA[<p>From the images you provided, the connector looks like a JST PH 2-pin connector:</p>
<li>Pin Count: Your connector has 2 pins.</li>
<li>Pitch (Pin Spacing): The spacing between the pins is likely 2.0 mm, which matches the JST PH series specification.</li>
<li>Shape and Latch: The rectangular plastic housing and latch design are typical of JST PH connectors.</li>
<p><strong>To replace:</strong><br />Female Side (Cable): Search for “JST PH 2.0mm 2-Pin Female Connector with Wires” (pre-assembled).<br />Male Side (PCB): Look for “JST PH 2.0mm 2-Pin Male Header” to solder onto the PCB.<br /><br />Alright, that mess on the board? Totally fixable. You can try this:</p>
<li>Grab some isopropyl alcohol (the stronger, the better – like 90%+).</li>
<li>Find a soft toothbrush (or anything soft-bristled). No need to get aggressive here; gentle scrubbing works best.</li>
<li>Dip the brush in alcohol and start scrubbing off the gunk. </li>
<li>For really stubborn spots, just pour a bit of alcohol directly onto the area – it’ll help loosen everything up.</li>
<li>Let it dry completely. Like, bone dry. Don’t rush and power it back on while it’s still damp – bad things will happen!</li>
<li>Once it’s all dry, take a closer look. Check for any broken traces or damage. If everything looks clean and intact, you’re good to go.</li>
If you want a quick visual guide on cleaning corroded PCBs, this video tutorial does a great job:<br /><a href="https://www.youtube.com/watch?v=f439OuFz-eQ" target="_blank" rel="noopener">How to Clean Battery Corrosion Off a PCB</a>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/basic-electronics-circuits-projects/what-connector-do-i-need/#post-262</guid>
                        <title>What connector do I need?</title>
                        <link>https://forum.etechnophiles.com/basic-electronics-circuits-projects/what-connector-do-i-need/#post-260</link>
                        <pubDate>Tue, 17 Dec 2024 23:15:03 +0000</pubDate>
                        <description><![CDATA[How can I tell what the specs are on this connector so I can replace it?  I need both the male and female sides. Do any of the numbers around the connector tell what it is?It connects the PC...]]></description>
                        <content:encoded><![CDATA[<p class="p1"><span class="s1"><span class="Apple-converted-space">How can I tell what the specs are on this connector so I can replace it?  I need both the male and female sides. <span>Do any of the numbers around the connector tell what it is?</span><br />It connects the PCB to a AAA battery compartment.  Forgot that the batteries were left in and they caused corrosion. </span></span></p>
<p class="p1"><span class="s1">Also, what is the best way to clean up  the PWB?</span></p>
<p class="p1"><span class="s1">Thanks</span></p>
<div id="wpfa-83" class="wpforo-attached-file"><a class="wpforo-default-attachment" title="IMG_2024-12-17-175606.jpeg" href="//forum.etechnophiles.com/wp-content/uploads/wpforo/default_attachments/1734477303-IMG_2024-12-17-175606.jpeg" target="_blank" rel="noopener"><i class="fas fa-paperclip"></i> IMG_2024-12-17-175606.jpeg</a></div>
<div id="wpfa-84" class="wpforo-attached-file"><a class="wpforo-default-attachment" title="IMG_2024-12-17-175047.jpeg" href="//forum.etechnophiles.com/wp-content/uploads/wpforo/default_attachments/1734477332-IMG_2024-12-17-175047.jpeg" target="_blank" rel="noopener"><i class="fas fa-paperclip"></i> IMG_2024-12-17-175047.jpeg</a></div>
<div id="wpfa-85" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.etechnophiles.com/wp-content/uploads/wpforo/default_attachments/1734477385-IMG_2024-12-17-175758.jpeg" target="_blank" title="IMG_2024-12-17-175758.jpeg"><i class="fas fa-paperclip"></i>&nbsp;IMG_2024-12-17-175758.jpeg</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/basic-electronics-circuits-projects/what-connector-do-i-need/#post-260</guid>
