									DMM in mA mode causes ~0.6 V drop — normal burden voltage? How can I minimize it? - Theoretical questions				            </title>
            <link>https://forum.etechnophiles.com/basic-electronics-theoretical-questions/dmm-in-ma-mode-causes-0-6-v-drop-normal-burden-voltage-how-can-i-minimize-it/</link>
            <lastBuildDate>Mon, 17 Aug 2026 04:57:11 +0000</lastBuildDate>
                        <title>Answer to: DMM in mA mode causes ~0.6 V drop — normal burden voltage? How can I minimize it?</title>
                        <link>https://forum.etechnophiles.com/basic-electronics-theoretical-questions/dmm-in-ma-mode-causes-0-6-v-drop-normal-burden-voltage-how-can-i-minimize-it/#post-1136</link>
                        <pubDate>Tue, 21 Oct 2025 06:16:19 +0000</pubDate>
                        <description><![CDATA[Yes, the 0.6 V drop you’re seeing is the meter’s burden voltage, which is the voltage lost across the DMM when it measures current. In mA mode, the meter places a small internal shunt resist...]]></description>
                        <content:encoded><![CDATA[<p>Yes, the 0.6 V drop you’re seeing is the meter’s burden voltage, which is the voltage lost across the DMM when it measures current. In mA mode, the meter places a small internal shunt resistor (and often a fuse or protection components) in series with your circuit to sense current, and this resistance causes a voltage drop equal to <span class="katex"><span class="katex-mathml">V=I×Rmeter</span><span class="katex-html" aria-hidden="true"><span class="base"><span class="mord"><span class="msupsub"><span class="vlist-t vlist-t2"><span class="vlist-r"><span class="vlist-s">​</span></span><span class="vlist-r"><span class="vlist"><span></span></span></span></span></span></span></span></span></span>.</p>
<p>For example, a 0.6 V drop at 60 mA means the meter adds about 10 Ω in series, which can significantly affect low-voltage circuits by reducing the actual voltage reaching your load.</p>
<p>To minimize this, you can use an external low-value shunt resistor and measure the voltage across it with the DMM in voltage mode, then calculate current using <span class="katex"><span class="katex-mathml">I=V/RI = V/R</span><span class="katex-html" aria-hidden="true"><span class="base"><span class="strut"></span><span class="mord mathnormal">I</span><span class="mspace"></span><span class="mrel">=</span><span class="mspace"></span></span><span class="base"><span class="strut"></span><span class="mord mathnormal">V</span><span class="mord">/</span><span class="mord mathnormal">R</span></span></span></span>.</p>
<p>Alternatively, use a dedicated low-burden current sense amplifier or sensor such as the INA219, a DC clamp probe that measures current without inserting resistance, or the meter’s 10 A input (which usually has much lower internal resistance) if the current is within safe limits.</p>
<p>These methods help keep the measurement accurate without disturbing the circuit’s operating voltage.</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/basic-electronics-theoretical-questions/">Theoretical questions</category>                        <dc:creator>nathan</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/basic-electronics-theoretical-questions/dmm-in-ma-mode-causes-0-6-v-drop-normal-burden-voltage-how-can-i-minimize-it/#post-1136</guid>
                        <title>DMM in mA mode causes ~0.6 V drop — normal burden voltage? How can I minimize it?</title>
                        <link>https://forum.etechnophiles.com/basic-electronics-theoretical-questions/dmm-in-ma-mode-causes-0-6-v-drop-normal-burden-voltage-how-can-i-minimize-it/#post-1100</link>
                        <pubDate>Thu, 09 Oct 2025 05:21:09 +0000</pubDate>
                        <description><![CDATA[I’m measuring the current draw of a low-voltage load and noticed my handheld DMM, in mA mode, is dropping about 0.6 V across itself. Is that normal “burden voltage,” and what’s the best way ...]]></description>
                        <content:encoded><![CDATA[<p><span>I’m measuring the current draw of a low-voltage load and noticed my handheld DMM, in mA mode, is dropping about 0.6 V across itself. Is that normal “burden voltage,” and what’s the best way to reduce it?</span></p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/basic-electronics-theoretical-questions/">Theoretical questions</category>                        <dc:creator>JannikTechy</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/basic-electronics-theoretical-questions/dmm-in-ma-mode-causes-0-6-v-drop-normal-burden-voltage-how-can-i-minimize-it/#post-1100</guid>
