									How do I choose the right op-amp for audio applications? - Theoretical questions				            </title>
            <link>https://forum.etechnophiles.com/basic-electronics-theoretical-questions/how-do-i-choose-the-right-op-amp-for-audio-applications/</link>
            <lastBuildDate>Sun, 13 Sep 2026 02:03:25 +0000</lastBuildDate>
                        <title>Answer to: How do I choose the right op-amp for audio applications?</title>
                        <link>https://forum.etechnophiles.com/basic-electronics-theoretical-questions/how-do-i-choose-the-right-op-amp-for-audio-applications/#post-1066</link>
                        <pubDate>Tue, 07 Oct 2025 07:00:01 +0000</pubDate>
                        <description><![CDATA[For audio op-amps, the big four are noise, slew rate, bandwidth/loop gain, and THD+N—matched to your source impedance and supply rails.
 Low‑impedance line stages favor low voltage‑noise bi...]]></description>
                        <content:encoded><![CDATA[<p><span>For audio op-amps, the big four are noise, slew rate, bandwidth/loop gain, and THD+N—matched to your source impedance and supply rails.</span></p>
<p><span> Low‑impedance line stages favor low voltage‑noise bipolars like NE5532/5534, LM4562/LME49720, or OPA1612; high‑impedance sources and filters prefer JFET inputs like OPA2134 or OPA1642/1656. Aim for a slew rate of at least 3–5 V/µs (10–20 V/µs gives margin) and enough GBW to leave healthy loop gain at 20 kHz; then verify THD+N at your actual level and load.</span></p>
<p><span> Check unity‑gain stability, output drive into 600 Ω/cables, and headroom—many classics assume ±12–15 V, while parts like OPA1656/OPA1688 excel at 5 V. Good layout, modest resistor values, and solid decoupling matter as much as the chip.</span></p>
<p><span> General‑purpose parts like LM358/741 will work, but their higher noise, limited slew rate, and distortion usually cap hi‑fi transparency.</span></p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/basic-electronics-theoretical-questions/">Theoretical questions</category>                        <dc:creator>Techyguy</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/basic-electronics-theoretical-questions/how-do-i-choose-the-right-op-amp-for-audio-applications/#post-1066</guid>
                        <link>https://forum.etechnophiles.com/basic-electronics-theoretical-questions/how-do-i-choose-the-right-op-amp-for-audio-applications/#post-738</link>
                        <pubDate>Tue, 30 Sep 2025 05:29:31 +0000</pubDate>
                        <description><![CDATA[For audio, the main things to look at in an op-amp are noise, slew rate, bandwidth, and THD+N. Low noise is important in preamp stages, a decent slew rate keeps transients clean, enough band...]]></description>
                        <content:encoded><![CDATA[<p data-start="148" data-end="424">For audio, the main things to look at in an op-amp are noise, slew rate, bandwidth, and THD+N. Low noise is important in preamp stages, a decent slew rate keeps transients clean, enough bandwidth avoids roll-off in the audio range, and low THD+N keeps the sound transparent.<br /><br />That’s why audio circuits usually use parts like the NE5532/5534, OPA2134, TL072, or LM4562/LME49720. They’re designed for low distortion and good sound quality.<br /><br />You can use general-purpose chips like LM358 or 741, but they’re noisier and distort more, so they’re not ideal for hi-fi. For anything beyond hobby-level, an audio-grade op-amp is the safer choice.</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/basic-electronics-theoretical-questions/">Theoretical questions</category>                        <dc:creator>Mehjabeen</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/basic-electronics-theoretical-questions/how-do-i-choose-the-right-op-amp-for-audio-applications/#post-738</guid>
                        <title>How do I choose the right op-amp for audio applications?</title>
                        <link>https://forum.etechnophiles.com/basic-electronics-theoretical-questions/how-do-i-choose-the-right-op-amp-for-audio-applications/#post-732</link>
                        <pubDate>Mon, 29 Sep 2025 05:28:54 +0000</pubDate>
                        <description><![CDATA[When it comes to audio circuits, I’ve seen many people emphasize the importance of choosing the right op-amp, since it can significantly affect noise, distortion, and overall sound quality....]]></description>
                        <content:encoded><![CDATA[<p data-start="131" data-end="338">When it comes to audio circuits, I’ve seen many people emphasize the importance of choosing the right op-amp, since it can significantly affect noise, distortion, and overall sound quality.</p>
<p data-start="340" data-end="565">What factors should be considered when selecting an op-amp specifically for audio applications? For example, how important are parameters like slew rate, input noise, bandwidth, or THD+N (Total Harmonic Distortion + Noise)?</p>
<p data-start="567" data-end="713">Are there certain op-amp families that are generally preferred for high-quality audio, and how do they compare to using general-purpose op-amps?</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/basic-electronics-theoretical-questions/">Theoretical questions</category>                        <dc:creator>Roshan</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/basic-electronics-theoretical-questions/how-do-i-choose-the-right-op-amp-for-audio-applications/#post-732</guid>
