									How to identify LED terminals? - Theoretical questions				            </title>
            <link>https://forum.etechnophiles.com/basic-electronics-theoretical-questions/how-to-identify-led-terminals/</link>
            <lastBuildDate>Sun, 13 Sep 2026 01:36:35 +0000</lastBuildDate>
                        <title>RE: How to identify LED terminals?</title>
                        <link>https://forum.etechnophiles.com/basic-electronics-theoretical-questions/how-to-identify-led-terminals/#post-705</link>
                        <pubDate>Wed, 17 Sep 2025 05:15:34 +0000</pubDate>
                        <description><![CDATA[@sebastian Good explanation! But what if the LED is part of a circuit and cannot be easily removed—what’s the safest way to identify the anode and cathode in-circuit?]]></description>
                        <content:encoded><![CDATA[@sebastian Good explanation! But what if the LED is part of a circuit and cannot be easily removed—what’s the safest way to identify the anode and cathode in-circuit?]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/basic-electronics-theoretical-questions/">Theoretical questions</category>                        <dc:creator>Deboojit</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/basic-electronics-theoretical-questions/how-to-identify-led-terminals/#post-705</guid>
                        <title>Answer to: How to identify LED terminals?</title>
                        <link>https://forum.etechnophiles.com/basic-electronics-theoretical-questions/how-to-identify-led-terminals/#post-117</link>
                        <pubDate>Thu, 19 Sep 2024 05:01:33 +0000</pubDate>
                        <description><![CDATA[Hi Aiden,To identify the anode and cathode of an LED, start with a visual inspection. Typically, the longer lead is the anode, and the shorter one is the cathode. If this method is not possi...]]></description>
                        <content:encoded><![CDATA[<div class="flex max-w-full flex-col flex-grow">
<div class="min-h- text-message flex w-full flex-col items-end gap-2 whitespace-normal break-words :mt-5" dir="auto" data-message-author-role="assistant" data-message-id="242a38e4-c4e1-4fb9-86d9-49e46c20402d">
<div class="flex w-full flex-col gap-1 empty:hidden first:pt-">
<div class="markdown prose w-full break-words dark:prose-invert light">
<p>Hi Aiden,<br /><br />To identify the anode and cathode of an LED, start with a visual inspection. Typically, the longer lead is the anode, and the shorter one is the cathode. If this method is not possible, another helpful visual indicator is the presence of a flat spot on the LED’s rim, which marks the cathode. If the internal structure is visible, the larger metal piece (die) inside the LED is connected to the cathode.<br /><br />If visual cues are unclear, electrical testing can be performed. Using a multimeter set to diode mode, place the probes on the leads; a reading will indicate that the anode is connected to the positive probe. Alternatively, you can connect a battery and resistor, attaching the positive terminal to one lead. If the LED lights up, the connected lead is the anode.</p>
<p><br />hope this will help</p>
</div>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/basic-electronics-theoretical-questions/">Theoretical questions</category>                        <dc:creator>Sebastian</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/basic-electronics-theoretical-questions/how-to-identify-led-terminals/#post-117</guid>
                        <title>How to identify LED terminals?</title>
                        <link>https://forum.etechnophiles.com/basic-electronics-theoretical-questions/how-to-identify-led-terminals/#post-116</link>
                        <pubDate>Sat, 14 Sep 2024 05:07:45 +0000</pubDate>
                        <description><![CDATA[Hi everyone,I&#039;m working on a school project that involves LEDs. I came across an LED where both the anode and cathode leads are of equal length, making it difficult to distinguish between th...]]></description>
                        <content:encoded><![CDATA[<p>Hi everyone,<br /><br />I'm working on a school project that involves LEDs. I came across an LED where both the anode and cathode leads are of equal length, making it difficult to distinguish between them using the typical lead length method. Additionally, the internal structure of the LED is not visible.</p>
<p>What are some reliable methods or techniques I can use to accurately identify the anode and cathode terminals in this situation?</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/basic-electronics-theoretical-questions/">Theoretical questions</category>                        <dc:creator>Aiden</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/basic-electronics-theoretical-questions/how-to-identify-led-terminals/#post-116</guid>
