									SPI vs I2C vs UART: which interface should I use for my application and why? - Theoretical questions				            </title>
            <link>https://forum.etechnophiles.com/basic-electronics-theoretical-questions/spi-vs-i2c-vs-uart-which-interface-should-i-use-for-my-application-and-why/</link>
            <lastBuildDate>Sun, 13 Sep 2026 01:48:58 +0000</lastBuildDate>
                        <title>Answer to: SPI vs I2C vs UART: which interface should I use for my application and why?</title>
                        <link>https://forum.etechnophiles.com/basic-electronics-theoretical-questions/spi-vs-i2c-vs-uart-which-interface-should-i-use-for-my-application-and-why/#post-1124</link>
                        <pubDate>Sat, 11 Oct 2025 05:32:01 +0000</pubDate>
                        <description><![CDATA[I²C is the best single interface choice for on-board sensors when the priorities are minimal pins, low power, and reliable data.
It uses just two shared wires, is supported by a wide range ...]]></description>
                        <content:encoded><![CDATA[<p data-start="2872" data-end="3305">I²C is the best single interface choice for on-board sensors when the priorities are minimal pins, low power, and reliable data.</p>
<p data-start="2872" data-end="3305">It uses just two shared wires, is supported by a wide range of low-power sensors, and enables software power-down strategies; address conflicts and pull-up sizing are the main practical considerations, both of which have straightforward hardware or firmware workarounds.</p>
<p data-start="3307" data-end="3511" data-is-last-node="" data-is-only-node="">If desired, a follow-up reply can include example pull-up values, suggested load-switch parts for power gating, or a short checklist to confirm sensor address and sleep capability before PCB finalization.</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/basic-electronics-theoretical-questions/">Theoretical questions</category>                        <dc:creator>Jaden</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/basic-electronics-theoretical-questions/spi-vs-i2c-vs-uart-which-interface-should-i-use-for-my-application-and-why/#post-1124</guid>
                        <title>SPI vs I2C vs UART: which interface should I use for my application and why?</title>
                        <link>https://forum.etechnophiles.com/basic-electronics-theoretical-questions/spi-vs-i2c-vs-uart-which-interface-should-i-use-for-my-application-and-why/#post-1116</link>
                        <pubDate>Fri, 10 Oct 2025 05:04:48 +0000</pubDate>
                        <description><![CDATA[I need to pick one interface before finalizing my PCB and firmware. Short on‑board sensor links; priorities are minimal pins, low power, and reliable data. Which would you choose and why?]]></description>
                        <content:encoded><![CDATA[<span>I need to pick one interface before finalizing my PCB and firmware. Short on‑board sensor links; priorities are minimal pins, low power, and reliable data. Which would you choose and why?</span>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/basic-electronics-theoretical-questions/">Theoretical questions</category>                        <dc:creator>techy ishan</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/basic-electronics-theoretical-questions/spi-vs-i2c-vs-uart-which-interface-should-i-use-for-my-application-and-why/#post-1116</guid>
