									Can measuring current the wrong way damage my multimeter? - Equipments				            </title>
            <link>https://forum.etechnophiles.com/equipments/can-measuring-current-the-wrong-way-damage-my-multimeter/</link>
            <lastBuildDate>Sun, 12 Apr 2026 15:48:16 +0000</lastBuildDate>
                        <title>Answer to: Can measuring current the wrong way damage my multimeter?</title>
                        <link>https://forum.etechnophiles.com/equipments/can-measuring-current-the-wrong-way-damage-my-multimeter/#post-494</link>
                        <pubDate>Wed, 25 Jun 2025 04:53:49 +0000</pubDate>
                        <description><![CDATA[Yes, if you measure current like voltage (in parallel), you can short the circuit and blow the multimeter fuse, or worse, damage it.Also, if the probe is left in the current port and you try...]]></description>
                        <content:encoded><![CDATA[<p>Yes, if you measure current like voltage (in parallel), you can short the circuit and blow the multimeter fuse, or worse, damage it.<br /><br />Also, if the probe is left in the current port and you try to measure voltage, it creates a short path and can seriously damage the meter or the circuit.<br /><br />Always switch the probe back to the voltage port and check your dial setting before measuring.</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/equipments/">Equipments</category>                        <dc:creator>TechTalks</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/equipments/can-measuring-current-the-wrong-way-damage-my-multimeter/#post-494</guid>
                        <title>Can measuring current the wrong way damage my multimeter?</title>
                        <link>https://forum.etechnophiles.com/equipments/can-measuring-current-the-wrong-way-damage-my-multimeter/#post-482</link>
                        <pubDate>Thu, 19 Jun 2025 05:29:11 +0000</pubDate>
                        <description><![CDATA[If I accidentally measure current like voltage (i.e., in parallel), can it damage my multimeter? Also, what happens if I leave the probe in the current port and try to measure voltage? Just ...]]></description>
                        <content:encoded><![CDATA[<p>If I accidentally measure current like voltage (i.e., in parallel), can it damage my multimeter? Also, what happens if I leave the probe in the current port and try to measure voltage? Just want to avoid any common mistakes.</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/equipments/">Equipments</category>                        <dc:creator>Bhavish</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/equipments/can-measuring-current-the-wrong-way-damage-my-multimeter/#post-482</guid>
