									How to Measure Capacitance with a Multimeter? - Equipments				            </title>
            <link>https://forum.etechnophiles.com/equipments/how-to-measure-capacitance-with-a-multimeter/</link>
            <lastBuildDate>Sun, 13 Sep 2026 02:38:02 +0000</lastBuildDate>
                        <title>Answer to: How to Measure Capacitance with a Multimeter?</title>
                        <link>https://forum.etechnophiles.com/equipments/how-to-measure-capacitance-with-a-multimeter/#post-536</link>
                        <pubDate>Fri, 04 Jul 2025 05:18:41 +0000</pubDate>
                        <description><![CDATA[Yes, you should always discharge the capacitor before measuring it with a multimeter. Measuring a charged capacitor can damage your meter and give false readings.Here&#039;s how to do it properly...]]></description>
                        <content:encoded><![CDATA[<p>Yes, you should always discharge the capacitor before measuring it with a multimeter. Measuring a charged capacitor can damage your meter and give false readings.<br /><br /><strong>Here's how to do it properly</strong>:</p>
<p><br />  1. Power off the circuit and remove the capacitor if possible. Measuring in-circuit often gives inaccurate results.<br /><br />  2. Discharge the capacitor safely:<br /><br />  3. Use a resistor (e.g., 1kΩ, 1W) across the leads.<br /><br />  4. Avoid shorting large electrolytics directly — they can spark or get damaged.<br /><br />  5. Set your multimeter to capacitance mode (⏀).<br /><br />  6. Connect the probes to the capacitor leads. Polarity doesn't matter for film or ceramic caps; for electrolytics,          follow meter instructions.<br /><br />  7. Wait a few seconds for the reading to stabilize — especially for high-value caps.<br /><br />Hope this helps!<br /><br /><br /></p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/equipments/">Equipments</category>                        <dc:creator>Paul</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/equipments/how-to-measure-capacitance-with-a-multimeter/#post-536</guid>
                        <link>https://forum.etechnophiles.com/equipments/how-to-measure-capacitance-with-a-multimeter/#post-518</link>
                        <pubDate>Wed, 02 Jul 2025 05:51:48 +0000</pubDate>
                        <description><![CDATA[Yes, definitely discharge the capacitor first — especially if it&#039;s a high-voltage one. A charged cap can damage your multimeter or give you completely wrong readings.
To discharge it, you c...]]></description>
                        <content:encoded><![CDATA[<p data-start="188" data-end="358">Yes, definitely discharge the capacitor first — especially if it's a high-voltage one. A charged cap can damage your multimeter or give you completely wrong readings.</p>
<p data-start="360" data-end="550">To discharge it, you can short the leads using a resistor (like 1kΩ or 10kΩ), or a screwdriver with an insulated handle if it's a small electrolytic (nothing high voltage though — not safe).</p>
<p data-start="552" data-end="580">Also, for accurate readings:</p>
<ul data-start="581" data-end="934">
<li data-start="581" data-end="704">
<p data-start="583" data-end="704">Take the capacitor out of the circuit if you can. In-circuit measurements are often wrong because of parallel components.</p>
<li data-start="705" data-end="779">
<p data-start="707" data-end="779">Let the multimeter settle for a few seconds, especially with large caps.</p>
<li data-start="780" data-end="832">
<p data-start="782" data-end="832">Make sure your test leads are making good contact.</p>
<li data-start="833" data-end="934">
<p data-start="835" data-end="934">If your meter has a "zero" or "rel" mode, use that to cancel out stray capacitance from the probes.</p>
<p data-start="936" data-end="1085">And keep in mind, these DMM readings are just a ballpark — they won’t tell you if the cap has high ESR or leakage. For that, you'd need an ESR meter.</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/equipments/">Equipments</category>                        <dc:creator>Amelia</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/equipments/how-to-measure-capacitance-with-a-multimeter/#post-518</guid>
                        <title>How to Measure Capacitance with a Multimeter?</title>
                        <link>https://forum.etechnophiles.com/equipments/how-to-measure-capacitance-with-a-multimeter/#post-492</link>
                        <pubDate>Tue, 24 Jun 2025 05:59:10 +0000</pubDate>
                        <description><![CDATA[I have a digital multimeter that includes a capacitance measuring mode, but I&#039;m not exactly sure how to use it properly. Do I need to discharge the capacitor first? Also, are there any tips ...]]></description>
                        <content:encoded><![CDATA[<p>I have a digital multimeter that includes a capacitance measuring mode, but I'm not exactly sure how to use it properly. Do I need to discharge the capacitor first? Also, are there any tips for getting accurate readings or avoiding mistakes when measuring capacitors with a multimeter?</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/equipments/">Equipments</category>                        <dc:creator>Techyguy</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/equipments/how-to-measure-capacitance-with-a-multimeter/#post-492</guid>
