									How to Test a Potentiometer with a Multimeter? - Equipments				            </title>
            <link>https://forum.etechnophiles.com/equipments/how-to-test-a-potentiometer-with-a-multimeter/</link>
            <lastBuildDate>Sun, 13 Sep 2026 02:01:24 +0000</lastBuildDate>
                        <title>Answer to: How to Test a Potentiometer with a Multimeter?</title>
                        <link>https://forum.etechnophiles.com/equipments/how-to-test-a-potentiometer-with-a-multimeter/#post-650</link>
                        <pubDate>Wed, 13 Aug 2025 05:46:13 +0000</pubDate>
                        <description><![CDATA[To test a potentiometer with a digital multimeter, first identify the terminals—the two outer pins are the ends of the resistive track, and the middle pin is the wiper.
Set the multimeter t...]]></description>
                        <content:encoded><![CDATA[<p data-start="61" data-end="113">To test a potentiometer with a digital multimeter, first identify the terminals—the two outer pins are the ends of the resistive track, and the middle pin is the wiper.</p>
<p data-start="61" data-end="113">Set the multimeter to resistance (Ω) mode and measure between the two outer pins; the reading should be close to the potentiometer’s rated value (such as 10 kΩ or 100 kΩ). If the value is open (infinite) or significantly different from the rating, the potentiometer is likely faulty.</p>
<p data-start="61" data-end="113">Next, check the smooth operation of the wiper by measuring between the middle pin and one outer pin while slowly rotating the knob; the resistance should change smoothly without sudden jumps or drops.</p>
<p data-start="61" data-end="113">Repeat the test with the middle pin and the other outer pin. Signs of a worn-out potentiometer include erratic resistance jumps, dead spots where no change occurs when turning, noisy readings, or an open circuit at certain positions. For more accurate results, avoid touching the metal probe tips with your fingers during measurement to prevent interference from body resistance.</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/equipments/">Equipments</category>                        <dc:creator>Tech Geek</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/equipments/how-to-test-a-potentiometer-with-a-multimeter/#post-650</guid>
                        <title>How to Test a Potentiometer with a Multimeter?</title>
                        <link>https://forum.etechnophiles.com/equipments/how-to-test-a-potentiometer-with-a-multimeter/#post-647</link>
                        <pubDate>Mon, 11 Aug 2025 06:26:34 +0000</pubDate>
                        <description><![CDATA[In my college lab, there are a lot of potentiometers, and I want to check which ones are still in good condition before using them in circuits. I have access to a standard digital multimeter...]]></description>
                        <content:encoded><![CDATA[<p>In my college lab, there are a lot of potentiometers, and I want to check which ones are still in good condition before using them in circuits. I have access to a standard digital multimeter but i dont know whats the correct procedure for testing them. Also, how can I tell if the potentiometer is faulty or worn out?</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/equipments/">Equipments</category>                        <dc:creator>electronic_God</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/equipments/how-to-test-a-potentiometer-with-a-multimeter/#post-647</guid>
