									Is it safe to use the multimeter’s amp setting on live circuits? - Equipments				            </title>
            <link>https://forum.etechnophiles.com/equipments/is-it-safe-to-use-the-multimeters-amp-setting-on-live-circuits/</link>
            <lastBuildDate>Sun, 12 Apr 2026 14:08:28 +0000</lastBuildDate>
                        <title>Answer to: Is it safe to use the multimeter’s amp setting on live circuits?</title>
                        <link>https://forum.etechnophiles.com/equipments/is-it-safe-to-use-the-multimeters-amp-setting-on-live-circuits/#post-1099</link>
                        <pubDate>Thu, 09 Oct 2025 05:02:29 +0000</pubDate>
                        <description><![CDATA[Definetly not, Dont switch to amps or move the red lead to the A/10A jack while your probes are on a live circuit. In A mode the meter is basically a short; flipping to it or probing voltage...]]></description>
                        <content:encoded><![CDATA[<p><span>Definetly not, Dont switch to amps or move the red lead to the A/10A jack while your probes are on a live circuit. In A mode the meter is basically a short; flipping to it or probing voltage with the lead in A can blow the fuse, make an arc, or worse.</span></p>
<p><span> Set the meter and leads with power off, break the circuit, insert the meter in series, then power up. For mains, use a clamp meter; for 12 V high-current systems be extra cautious or use a clamp/shunt. And always move the red lead back to V when you’re done to avoid the classic “next-time short.”</span></p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/equipments/">Equipments</category>                        <dc:creator>Neeraj Dev</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/equipments/is-it-safe-to-use-the-multimeters-amp-setting-on-live-circuits/#post-1099</guid>
                        <link>https://forum.etechnophiles.com/equipments/is-it-safe-to-use-the-multimeters-amp-setting-on-live-circuits/#post-576</link>
                        <pubDate>Mon, 14 Jul 2025 04:47:34 +0000</pubDate>
                        <description><![CDATA[No, it&#039;s not safe to switch to amp mode or connect the meter in amp mode while the circuit is powered, especially not on high voltage (like AC mains) or even high-current 12V DC systems (lik...]]></description>
                        <content:encoded><![CDATA[<p>No, it's not safe to switch to amp mode or connect the meter in amp mode while the circuit is powered, especially not on high voltage (like AC mains) or even high-current 12V DC systems (like car batteries).</p>
<p>When your multimeter is in current mode, it's basically acting like a piece of wire—it has very low resistance. If you try to connect it across a live circuit (like you would for voltage), you're basically shorting the power source, and that can result in Blown fuse in the meter (if you're lucky), Arcs or sparks. </p>
<p>So, If you dont want that Always power off the circuit before measuring current. Break the circuit and insert the meter in series, making sure the probes are in the correct ports—especially the high current port if you're measuring above ~200mA.</p>
<p>Once everything's connected, power on the circuit, take your reading, and then power it off again before removing the meter.</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/equipments/">Equipments</category>                        <dc:creator>cooper</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/equipments/is-it-safe-to-use-the-multimeters-amp-setting-on-live-circuits/#post-576</guid>
                        <title>Is it safe to use the multimeter’s amp setting on live circuits?</title>
                        <link>https://forum.etechnophiles.com/equipments/is-it-safe-to-use-the-multimeters-amp-setting-on-live-circuits/#post-572</link>
                        <pubDate>Sat, 12 Jul 2025 07:04:07 +0000</pubDate>
                        <description><![CDATA[I’ve seen warnings about using the current (amp) setting on a multimeter, and I want to be cautious. I understand that to measure current, the meter has to be placed in series with the load....]]></description>
                        <content:encoded><![CDATA[<p data-start="150" data-end="505">I’ve seen warnings about using the current (amp) setting on a multimeter, and I want to be cautious. I understand that to measure current, the meter has to be placed in series with the load. But I’m unsure about the risks involved when doing this on a live circuit, especially with higher voltages like AC mains or even 12V DC systems with decent current. Is it safe to switch to the amp mode while the circuit is powered?</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/equipments/">Equipments</category>                        <dc:creator>techy ishan</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/equipments/is-it-safe-to-use-the-multimeters-amp-setting-on-live-circuits/#post-572</guid>
