									Measuring current with oscilloscope? - Equipments				            </title>
            <link>https://forum.etechnophiles.com/equipments/measuring-current-with-oscilloscope/</link>
            <lastBuildDate>Sun, 12 Apr 2026 15:46:55 +0000</lastBuildDate>
                        <title>Answer to: Measuring current with oscilloscope?</title>
                        <link>https://forum.etechnophiles.com/equipments/measuring-current-with-oscilloscope/#post-342</link>
                        <pubDate>Fri, 07 Feb 2025 13:00:40 +0000</pubDate>
                        <description><![CDATA[Yes, you can use an oscilloscope with a current probe for the best accuracy and convenience. Alternatively, you can use a shunt resistor in series and measure the voltage drop to calculate c...]]></description>
                        <content:encoded><![CDATA[<p>Yes, you can use an oscilloscope with a current probe for the best accuracy and convenience. Alternatively, you can use a shunt resistor in series and measure the voltage drop to calculate current (<span class="katex"><span class="katex-mathml">I=V/R</span></span>).</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/equipments/">Equipments</category>                        <dc:creator>Sebastian</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/equipments/measuring-current-with-oscilloscope/#post-342</guid>
                        <link>https://forum.etechnophiles.com/equipments/measuring-current-with-oscilloscope/#post-252</link>
                        <pubDate>Mon, 09 Dec 2024 06:24:16 +0000</pubDate>
                        <description><![CDATA[An oscilloscope, a device primarily designed for voltage measurements, can also be effectively used to measure current. One method involves employing a shunt resistor, a low-resistance compo...]]></description>
                        <content:encoded><![CDATA[<p>An oscilloscope, a device primarily designed for voltage measurements, can also be effectively used to measure current. One method involves employing a shunt resistor, a low-resistance component placed in series with the circuit.</p>
<p>By measuring the voltage drop across this resistor, which is directly proportional to the current flowing through it according to Ohm's Law (V = IR), the current value can be determined.</p>
<p>Alternatively, a current probe can be utilized. This specialized tool directly senses the magnetic field generated by the current flow and converts it into a proportional voltage, which is then displayed by the oscilloscope.</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/equipments/">Equipments</category>                        <dc:creator>Jaden</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/equipments/measuring-current-with-oscilloscope/#post-252</guid>
                        <title>Measuring current with oscilloscope?</title>
                        <link>https://forum.etechnophiles.com/equipments/measuring-current-with-oscilloscope/#post-241</link>
                        <pubDate>Mon, 02 Dec 2024 05:23:11 +0000</pubDate>
                        <description><![CDATA[I’m working on a project where I need to check the current drawn by a circuit during different states. Is it possible to use an oscilloscope for this?]]></description>
                        <content:encoded><![CDATA[<p>I’m working on a project where I need to check the current drawn by a circuit during different states. Is it possible to use an oscilloscope for this?</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/equipments/">Equipments</category>                        <dc:creator>Digital Dynamo</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/equipments/measuring-current-with-oscilloscope/#post-241</guid>
