									ESP32 - eTechnophiles Forum				            </title>
            <link>https://forum.etechnophiles.com/esp32/</link>
            <lastBuildDate>Mon, 17 Aug 2026 04:34:37 +0000</lastBuildDate>
                        <title>esp32 diagram connection</title>
                        <link>https://forum.etechnophiles.com/esp32/esp32-diagram-connection/</link>
                        <pubDate>Wed, 18 Mar 2026 06:39:50 +0000</pubDate>
                        <description><![CDATA[i never use esp32 before i get diagram from claude i want to u too guys to checi s this diagram ok i have attached with this. u
&nbsp;wiring_v3_470fix.png]]></description>
                        <content:encoded><![CDATA[<p>i never use esp32 before i get diagram from claude i want to u too guys to checi s this diagram ok i have attached with this. u</p>
<div id="wpfa-236" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.etechnophiles.com/wp-content/uploads/wpforo/default_attachments/1773815990-wiring_v3_470fix.png" target="_blank" title="wiring_v3_470fix.png"><i class="fas fa-paperclip"></i>&nbsp;wiring_v3_470fix.png</a></div>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/esp32/">ESP32</category>                        <dc:creator>wmughal</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/esp32/esp32-diagram-connection/</guid>
                        <title>Can ESP32 stream audio over Wi-Fi or Bluetooth?</title>
                        <link>https://forum.etechnophiles.com/esp32/can-esp32-stream-audio-over-wi-fi-or-bluetooth/</link>
                        <pubDate>Mon, 01 Sep 2025 05:06:45 +0000</pubDate>
                        <description><![CDATA[I’m working on a project where I need to send audio from an ESP32, and I’m trying to figure out if it’s possible to stream audio over Wi-Fi or Bluetooth. If anyone has tried this, which libr...]]></description>
                        <content:encoded><![CDATA[<p data-start="181" data-end="590">I’m working on a project where I need to send audio from an ESP32, and I’m trying to figure out if it’s possible to stream audio over Wi-Fi or Bluetooth. If anyone has tried this, which libraries or methods did you use?</p>
<p data-start="181" data-end="590">I’m also curious about how well it works in practice in terms of audio quality and latency, and whether certain ESP32 variants perform better for this.</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/esp32/">ESP32</category>                        <dc:creator>Nitin arora</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/esp32/can-esp32-stream-audio-over-wi-fi-or-bluetooth/</guid>
                        <title>ESP32-C3 vs ESP32-S3 — which one to go with?</title>
                        <link>https://forum.etechnophiles.com/esp32/esp32-c3-vs-esp32-s3-which-one-to-go-with/</link>
                        <pubDate>Sat, 30 Aug 2025 05:05:05 +0000</pubDate>
                        <description><![CDATA[I need a board with native USB support for HID or custom USB projects, and I’m trying to decide between the ESP32-C3 and ESP32-S3. Do both support native USB, and which one is more reliable ...]]></description>
                        <content:encoded><![CDATA[<p>I need a board with native USB support for HID or custom USB projects, and I’m trying to decide between the ESP32-C3 and ESP32-S3. Do both support native USB, and which one is more reliable for this purpose?</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/esp32/">ESP32</category>                        <dc:creator>zaid</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/esp32/esp32-c3-vs-esp32-s3-which-one-to-go-with/</guid>
                        <title>Using ESP32 with DHT11, PIR, and MPU6050 sensors</title>
                        <link>https://forum.etechnophiles.com/esp32/using-esp32-with-dht11-pir-and-mpu6050-sensors/</link>
                        <pubDate>Wed, 27 Aug 2025 05:38:24 +0000</pubDate>
                        <description><![CDATA[How can I connect sensors like DHT11, PIR motion sensor, and MPU6050 to an ESP32? Do they work directly with 3.3V, and are there any specific libraries or wiring tips I should know about?]]></description>
                        <content:encoded><![CDATA[<p>How can I connect sensors like DHT11, PIR motion sensor, and MPU6050 to an ESP32? Do they work directly with 3.3V, and are there any specific libraries or wiring tips I should know about?</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/esp32/">ESP32</category>                        <dc:creator>TechyNik</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/esp32/using-esp32-with-dht11-pir-and-mpu6050-sensors/</guid>
                        <title>Why do people use Teensy for custom keyboards instead of Arduino boards?</title>
                        <link>https://forum.etechnophiles.com/esp32/why-do-people-use-teensy-for-custom-keyboards-instead-of-arduino-boards/</link>
                        <pubDate>Mon, 25 Aug 2025 05:03:14 +0000</pubDate>
                        <description><![CDATA[I’ve seen many DIY keyboard projects where people use a Teensy microcontroller rather than popular Arduino boards like the Uno, Nano, or Pro Mini. What makes the Teensy a better choice for k...]]></description>
                        <content:encoded><![CDATA[<p>I’ve seen many DIY keyboard projects where people use a Teensy microcontroller rather than popular Arduino boards like the Uno, Nano, or Pro Mini. What makes the Teensy a better choice for keyboards? Is it related to USB support, performance, or something else.</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/esp32/">ESP32</category>                        <dc:creator>electronic_God</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/esp32/why-do-people-use-teensy-for-custom-keyboards-instead-of-arduino-boards/</guid>
                        <title>How to Reliably Reconnect ESP32/ESP8266 to Wi-Fi Without Rebooting?</title>
                        <link>https://forum.etechnophiles.com/esp32/how-to-reliably-reconnect-esp32-esp8266-to-wi-fi-without-rebooting/</link>
                        <pubDate>Thu, 10 Jul 2025 06:56:11 +0000</pubDate>
                        <description><![CDATA[I&#039;m using an ESP32 (also applies to ESP8266) in a project that needs to maintain a stable Wi-Fi connection. Occasionally, the Wi-Fi connection drops—due to signal issues or router resets—and...]]></description>
                        <content:encoded><![CDATA[<p>I'm using an ESP32 (also applies to ESP8266) in a project that needs to maintain a stable Wi-Fi connection. Occasionally, the Wi-Fi connection drops—due to signal issues or router resets—and the device doesn't reconnect automatically unless I manually reboot it.<br /><br />I want to know how to automatically detect a dropped Wi-Fi connection and reconnect to it programmatically, without having to reset the entire board.</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/esp32/">ESP32</category>                        <dc:creator>Philippe</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/esp32/how-to-reliably-reconnect-esp32-esp8266-to-wi-fi-without-rebooting/</guid>
                        <title>Best Cheap as Possible ESP32 Boards?</title>
                        <link>https://forum.etechnophiles.com/esp32/best-cheap-as-possible-esp32-boards/</link>
                        <pubDate>Wed, 09 Jul 2025 06:05:18 +0000</pubDate>
                        <description><![CDATA[I’m looking to get started with ESP32 development and want to find the most affordable board that still works reliably. There are so many variants out there—ESP32-WROOM, ESP32-C3, ESP32-S3, ...]]></description>
                        <content:encoded><![CDATA[<p data-start="116" data-end="343">I’m looking to get started with ESP32 development and want to find the most affordable board that still works reliably. There are so many variants out there—ESP32-WROOM, ESP32-C3, ESP32-S3, and countless clones.</p>
<p data-start="345" data-end="637">What are the cheapest ESP32 boards you've used that still perform well for basic projects like Wi-Fi control, sensor data logging, or IoT experiments? Are the ultra-cheap boards from sites like AliExpress or Amazon worth it, or do they come with issues like instability or poor build quality?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/esp32/best-cheap-as-possible-esp32-boards/</guid>
                        <title>Why does my ESP8266 keep restarting?</title>
                        <link>https://forum.etechnophiles.com/esp32/why-does-my-esp8266-keep-restarting/</link>
                        <pubDate>Wed, 25 Jun 2025 05:30:14 +0000</pubDate>
                        <description><![CDATA[I just got a brand new ESP8266 and tried uploading a basic sketch (just a simple Serial.begin() and a few prints), but as soon as it runs, the board keeps restarting in a loop.
I haven’t co...]]></description>
                        <content:encoded><![CDATA[<p data-start="208" data-end="398">I just got a brand new ESP8266 and tried uploading a basic sketch (just a simple <code data-start="301" data-end="317">Serial.begin()</code> and a few prints), but as soon as it runs, the board keeps restarting in a loop.</p>
<p data-start="400" data-end="563">I haven’t connected any sensors or peripherals — just powered it via USB. The Serial Monitor keeps showing reset messages like <code data-start="527" data-end="541">rst cause: 4</code> or something similar.</p>
<p data-start="565" data-end="734">Is this normal for a new board? Could it be a power issue, bad code, or something else I’m missing?<br data-start="664" data-end="667" />Would really appreciate any suggestions before I start panicking</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/esp32/">ESP32</category>                        <dc:creator>DIY Electronica</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/esp32/why-does-my-esp8266-keep-restarting/</guid>
                        <title>How to interface a temperature sensor with an ESP32?</title>
                        <link>https://forum.etechnophiles.com/esp32/how-to-interface-a-temperature-sensor-with-an-esp32/</link>
                        <pubDate>Thu, 15 May 2025 05:29:41 +0000</pubDate>
                        <description><![CDATA[Hi everyone,
I&#039;m working on my college project titled &quot;Temperature Monitoring System using ESP32&quot;, where I&#039;m using a DHT11 sensor to measure temperature and humidity. I connected the sensor...]]></description>
                        <content:encoded><![CDATA[<p data-start="243" data-end="484">Hi everyone,</p>
<p data-start="243" data-end="484"><br data-start="267" data-end="270" />I'm working on my college project titled "Temperature Monitoring System using ESP32", where I'm using a DHT11 sensor to measure temperature and humidity. I connected the sensor to my ESP32 board as follows:<br /><br />1. VCC to 3.3V<br /><br />2. GND to GND<br /><br />2. DATA to GPIO4<br /><br />I installed the Adafruit DHT library, uploaded the example sketch, and opened the Serial Monitor. But instead of getting temperature readings, it keeps printing<br /><br /></p>
<pre contenteditable="false">Failed to read from DHT sensor!</pre>
<p data-start="243" data-end="484"><br />And sometimes it shows 0.00 °C, which is wrong.<br /><br />I tried the following, but still couldn’t get consistent results:<br /><br />1. Double-checked wiring<br /><br />2. Used different GPIO pins<br /><br />3. Increased delay between reads<br /><br />Any help would be greatly appreciated!</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/esp32/">ESP32</category>                        <dc:creator>Electronix</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/esp32/how-to-interface-a-temperature-sensor-with-an-esp32/</guid>
                        <title>ESP32 vs RP2040 – Which is better after Arduino?</title>
                        <link>https://forum.etechnophiles.com/esp32/esp32-vs-rp2040-which-is-better-after-arduino/</link>
                        <pubDate>Thu, 01 May 2025 06:08:35 +0000</pubDate>
                        <description><![CDATA[I&#039;ve worked with Arduino before and want to try something new for my next robotics project. I&#039;m considering either the ESP32 or the RP2040. The project might involve sensors and wireless com...]]></description>
                        <content:encoded><![CDATA[<p>I've worked with Arduino before and want to try something new for my next robotics project. I'm considering either the ESP32 or the RP2040. The project might involve sensors and wireless communication. Which board would be a better step forward, and why?</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/esp32/">ESP32</category>                        <dc:creator>Neil_Overtorn</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/esp32/esp32-vs-rp2040-which-is-better-after-arduino/</guid>
