									How to Reliably Reconnect ESP32/ESP8266 to Wi-Fi Without Rebooting? - ESP32				            </title>
            <link>https://forum.etechnophiles.com/esp32/how-to-reliably-reconnect-esp32-esp8266-to-wi-fi-without-rebooting/</link>
            <lastBuildDate>Sun, 12 Apr 2026 09:20:20 +0000</lastBuildDate>
                        <title>Answer to: How to Reliably Reconnect ESP32/ESP8266 to Wi-Fi Without Rebooting?</title>
                        <link>https://forum.etechnophiles.com/esp32/how-to-reliably-reconnect-esp32-esp8266-to-wi-fi-without-rebooting/#post-703</link>
                        <pubDate>Tue, 16 Sep 2025 05:22:03 +0000</pubDate>
                        <description><![CDATA[This is a very common issue with ESP boards, as a dropped connection won&#039;t automatically trigger a new connection attempt unless the logic is specifically handled in your code. The most reli...]]></description>
                        <content:encoded><![CDATA[<p>This is a very common issue with ESP boards, as a dropped connection won't automatically trigger a new connection attempt unless the logic is specifically handled in your code. The most reliable and efficient way to solve this is by using a Wi-Fi event handler.<br /><br />This approach is superior to periodically checking the connection status because it's event-driven. Your code will react immediately to a disconnection event, rather than waiting for a specific time interval to check if the Wi-Fi is still connected.</p>
<p>The event-driven method is more efficient because your code reacts instantly when the ESP disconnects, instead of waiting for a timer to notice the problem. For example, on the ESP32 you can use:</p>
<pre contenteditable="false">#include &lt;WiFi.h&gt;
void WiFiEvent(WiFiEvent_t event) {
  switch (event) {
    case SYSTEM_EVENT_STA_DISCONNECTED:
      Serial.println("WiFi disconnected! Reconnecting...");
      WiFi.reconnect();
      break;
    case SYSTEM_EVENT_STA_CONNECTED:
      Serial.println("WiFi connected!");
      break;
  Serial.begin(115200);
  WiFi.onEvent(WiFiEvent);
  WiFi.begin("YourSSID", "YourPassword");
  // Your main code
<p>With this setup, the ESP automatically attempts to reconnect whenever the connection drops, without wasting resources on continuous polling.</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/esp32/">ESP32</category>                        <dc:creator>Neeraj Dev</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/esp32/how-to-reliably-reconnect-esp32-esp8266-to-wi-fi-without-rebooting/#post-703</guid>
                        <title>How to Reliably Reconnect ESP32/ESP8266 to Wi-Fi Without Rebooting?</title>
                        <link>https://forum.etechnophiles.com/esp32/how-to-reliably-reconnect-esp32-esp8266-to-wi-fi-without-rebooting/#post-569</link>
                        <pubDate>Thu, 10 Jul 2025 06:56:11 +0000</pubDate>
                        <description><![CDATA[I&#039;m using an ESP32 (also applies to ESP8266) in a project that needs to maintain a stable Wi-Fi connection. Occasionally, the Wi-Fi connection drops—due to signal issues or router resets—and...]]></description>
                        <content:encoded><![CDATA[<p>I'm using an ESP32 (also applies to ESP8266) in a project that needs to maintain a stable Wi-Fi connection. Occasionally, the Wi-Fi connection drops—due to signal issues or router resets—and the device doesn't reconnect automatically unless I manually reboot it.<br /><br />I want to know how to automatically detect a dropped Wi-Fi connection and reconnect to it programmatically, without having to reset the entire board.</p>]]></content:encoded>
						                            <category domain="https://forum.etechnophiles.com/esp32/">ESP32</category>                        <dc:creator>Philippe</dc:creator>
                        <guid isPermaLink="true">https://forum.etechnophiles.com/esp32/how-to-reliably-reconnect-esp32-esp8266-to-wi-fi-without-rebooting/#post-569</guid>
