03/07/2025 11:48 am
Is it possible to use analog pins as digital output? If yes, how to do this? I mean what command should I type?
25/08/2025 4:50 am
Yes, on Arduino boards the analog pins can also function as digital I/O pins. Each analog pin has a digital pin number assigned internally (for example, on Arduino Uno A0 = D14, A1 = D15, and so on). To use them as digital outputs, you simply use the same commands as with normal digital pins:
Here, A0 is used directly, but you can also refer to it by its digital pin number (like 14 for A0). This allows you to extend the number of available digital I/O pins on your Arduino.
This post was modified 8 months ago by Paul
