Setting multiple pi...
[Solved] Setting multiple pins as OUTPUT
5 Users
4 Reactions
Hi,
I am using 8 digital pins to control the 8 LEDs separately. Instead of writing "pinMode(pin,OUTPUT)" for every other pin, is there any short method?
2
For loop will do the job if the pins are in series:
for (int i = 2; i <= 9; i++) {
pinMode(i, OUTPUT);
If pins are random, use an array like this:
int buttons[]={2,4,5,8,10,13};
for(int i:buttons){
pinMode(i, OUTPUT);
Mehjabeen Topic starter 06/09/2024 6:22 am
@ankunegi Thank you. You are a life saver!!
1
You can use for loop for this; here's how
pinMode(i, OUTPUT);
This loop goes from pin 2 to 9 and sets each pin as OUTPUT.
Mehjabeen Topic starter 10/05/2024 5:50 am
@jignesh What if the pins are not in series? For example 2,4,5,8,10,13.
Admin Admin 29/08/2024 7:21 am
@jignesh You can use an array: int buttons[]={2,4,5,8,10,13,}; for(int i:buttons){ pinMode(i, OUTPUT); }
1
Here's an example using a for loop to configure 8 digital pins (from pin 2 to pin 9) as outputs:
int ledPins[] = {2, 3, 4, 5, 6, 7, 8, 9}; // Array of pin numbers
  for (int i = 0; i < 8; i++) {
    pinMode(ledPins[i], OUTPUT); // Set each pin as an output
  // Your code to control LEDs goes here
If the pins are not in a series, you can still use an array:
int ledPins[] = {2, 5, 7, 8, 10, 12, 13, A0}; // Array of specific pin numbers
    pinMode(ledPins[i], OUTPUT); // Set each specified pin as an output
