Why does my Servo m...
Why does my Servo motor Jitter instead of holding position?
I'm trying to control a servo using my Arduino, but I'm facing an issue where the servo jitters instead of holding its position. Even when I send a fixed angle using servo.write(), it moves slightly back and forth instead of staying still.
Here's my basic setup:
  • Arduino Uno
  • SG90 servo motor powered from the Arduino's 5V pin
  • Signal wire connected to pin 9
#include <Servo.h>
Servo myServo;
    myServo.attach(9);
    myServo.write(90);
I've tried adding delay(1000); in the loop, but that didn't help. Do I need a separate power source for the servo, or is there another way to fix the jitter? Any advice would be greatly appreciated.
The jitter is most likely caused by power issues or signal noise. Since you're powering the SG90 servo from the Arduino's 5V pin, that might not provide enough current, leading to unstable movements. I've run into this before, and here’s what helped me fix it:
Quick Fixes:
  • Use an external 5V–6V power source for the servo instead of the Arduino’s 5V pin. Connect all GNDs together.
  • Add a 100µF capacitor across the servo’s VCC & GND to stabilize power.
  • Keep signal wires short to reduce interference.
If the issue persists, try this simple code to maintain position(let me know whether this works or not):
#include <Servo.h>
Servo myServo;
    myServo.attach(9);
    myServo.write(90);
    delay(20); // Helps stabilize position
One more thing, if you’re using a cheap SG90 clone, some jittering is just part of the deal.
hobart bess Topic starter 27/03/2025 5:27 am
@ankunegi I tried the fixes you suggested:
1. Slight improvement, but the servo is still jittering.
2. No effect at all.
3. I bought a brand-new original SG90—and surprisingly, it worked perfectly! No jitters whatsoever.
