Best practical uses...
Best practical uses of continuity function on a multimeter?
3 Users
Hello everyone,
I just started using a multimeter for testing circuits, and I’m particularly curious about the continuity function. I’ve used it a couple of times to check connections, but I’d like to learn more about when and where it's most useful.
Can anyone share some practical examples or tips for getting the most out of this feature, especially for troubleshooting circuits and components?
Hey there! The continuity function on a multimeter is super handy, especially when you're troubleshooting. It's the only function I have used more than a few hundred times. Sounds like you’re already on the right track using it to check connections, but here are some more ways I’ve found it useful:
  1. Broken Wires: I use it all the time to check for breaks in wires. Especially when making breadboard projects. The jumper wires really annoy me when I find out the circuit is not working because of just that one faulty jumper wire.  So now, before using any jumper wire, I always test them for continuity. Just touch the probes to each end of the wire—if it beeps, the wire’s good. No beep? The wire’s probably busted somewhere.
  2. Bad Connections: It’s great for checking if your soldering job is solid. Just probe both ends of the connection; if it beeps, you’re golden. Saves a ton of time compared to hunting down bad connections manually.
  3. Switches: Got a dodgy switch? Test it in both positions. If it doesn’t beep in the "on" position, it’s toast.
  4. Fuses: Continuity is the easiest way to test fuses. If it beeps, the fuse is fine. No beep = dead fuse.
  5. Short Circuits: You can also check for shorts. If you’re getting continuity between two points that shouldn’t be connected, you might have a short (solder bridge, etc.).
These are some of the uses I can think of right now but not limited to this only. 🙂
