Difference Between ...
Difference Between a Latch and a Flip‑Flop?
1 Reactions
While studying basic digital circuits, I’ve come across both latches and flip‑flops used for storing a single bit. Sources say latches are level‑triggered and flip‑flops are edge‑triggered, but I’m still unclear on what that means in practice.
Could someone explain—using beginner‑friendly terms—how their operation differs, where each device is typically used, and any pros or cons that matter in simple designs?
1
This is one of the most commonly asked and slightly confusing questions for beginners in electronics engineering. Both latch and flip-flop are fundamental building blocks in digital electronics used for storing binary information, but they differ primarily in how they respond to input signals.
A latch is level-triggered, meaning it continuously monitors its inputs and changes its output as long as the enable signal is active.
In contrast, a flip-flop is edge-triggered, meaning it only changes its output at a specific moment—either on the rising or falling edge of a clock signal.
This makes flip-flops more suitable for synchronous designs where precise timing is essential. Latches are generally simpler and faster but are more prone to glitches in timing-sensitive applications.
Flip-flops, although slightly more complex, provide better control and stability in clocked systems such as registers and counters.
