Difference between ...
Difference between active and passive buzzer and how to identify them?
I'm working on a project based on a tank water level control system. I need to include a buzzer for sound alerts, but I know nothing about buzzers. I've come across active and passive buzzers, but I'm not sure which one would be the best choice for this project.
Can anyone provide information on which would be more suitable, the key differences between active and passive buzzers, and how to identify each type?
For a tank water level control system, both active and passive buzzers can be used for sound alerts, but which one is best depends on your needs.
Key Differences:
Active Buzzer: This type comes with an internal oscillating circuit, meaning it generates sound as soon as you power it. You don't need any extra control or signal from a microcontroller—just apply voltage (like 5V), and it will produce a constant tone. This is ideal for simple "on/off" alerts.
  • Pros: Easy to use, no extra coding needed to generate sound.
  • Cons: Fixed tone—no control over pitch or frequency.
  • How to Identify: Usually labeled "active," and when you apply power, it immediately produces a sound.
Passive Buzzer: Unlike the active type, passive buzzers require an external signal (usually a square wave) to generate sound. This means you can control the pitch and create different tones using Arduino's tone() function or PWM.
  • Pros: Flexible—can generate different tones.
  • Cons: Needs a signal to work, so it's a bit more complicated to implement.
  • How to Identify: Labeled as "passive" or "magnetic," and won’t make any sound without a sign
Which One to Choose?
If you just need a basic alert (e.g., water level too high/low), an active buzzer is the simplest option—just plug it in and go. However, if you want to vary the sound based on the water level, go with a passive buzzer, though it will require more coding.
