How can I secure my...
How can I secure my IoT devices from hacking?
I have IoT devices at home, such as smart plugs, cameras, and sensors, and I use them in various projects. I'm concerned about the risk of hacking and want to ensure that all devices are secure.
What are the best practices to protect IoT devices from unauthorized access and cyber threats?
Yeah, securing IoT devices is super important, especially since they're often connected to the internet with minimal protection. Here are a few good practices I follow to keep them safe:
  • Change default credentials: First thing I do is change the default usernames and passwords on devices and routers. Leaving them as-is is basically an open invitation for hackers.
  • Use strong passwords and encryption: I always use strong passwords and make sure communication between devices (like ESP32s or Raspberry Pi) is encrypted—MQTTS, HTTPS, or at least SSL/TLS if possible.
  • Secure the Wi-Fi network: Make sure you’re using WPA2 or WPA3, and turn off WPS. I also set up a separate network just for IoT stuff so it’s isolated from my main devices.
  • Keep everything updated: Firmware and libraries can have security holes, so I make it a habit to check for updates regularly.
  • Disable what you don’t need: If I’m not using features like OTA updates or web servers, I just disable them to reduce the attack surface.
  • Firewall and network segmentation: A basic firewall setup helps a lot. If your router supports VLANs or guest networks, use them to keep IoT devices separated.
  • Access control: I try to use API keys or tokens when connecting to cloud services, just to make sure only authorized devices can talk to them.
  • Monitor behavior: It’s helpful to log activity or use a tool that alerts you if something unusual happens—like random reboots or failed login attempts.
  • Avoid hardcoding sensitive data: Instead of putting Wi-Fi passwords or tokens directly in the code, I load them from a config file or EEPROM.
  • Physical security matters too: If your devices are in public or outdoor places, protect USB ports, buttons, and serial pins—they can be exploited physically.
