SPI vs I2C vs UART:...
SPI vs I2C vs UART: which interface should I use for my application and why?
I need to pick one interface before finalizing my PCB and firmware. Short on‑board sensor links; priorities are minimal pins, low power, and reliable data. Which would you choose and why?
I²C is the best single interface choice for on-board sensors when the priorities are minimal pins, low power, and reliable data.
It uses just two shared wires, is supported by a wide range of low-power sensors, and enables software power-down strategies; address conflicts and pull-up sizing are the main practical considerations, both of which have straightforward hardware or firmware workarounds.
If desired, a follow-up reply can include example pull-up values, suggested load-switch parts for power gating, or a short checklist to confirm sensor address and sleep capability before PCB finalization.
