What is the differe...
What is the difference between low-pass and high-pass filters?
I’m trying to understand the fundamental differences between low-pass and high-pass electronic filters. I gather that a low-pass filter allows low frequencies to pass while attenuating high frequencies, whereas a high-pass filter does the opposite.
I’m particularly interested in how their circuit designs differ, their common applications, and how factors like cutoff frequency and filter order affect their performance. Any insights or explanations would be greatly appreciated!
A low-pass filter (LPF) allows low-frequency signals to pass while attenuating higher frequencies, helping to remove high-frequency noise and smooth signals.
In contrast, a high-pass filter (HPF) allows high-frequency signals to pass while blocking lower frequencies, commonly used to eliminate low-frequency noise or DC offset. Both filters can be implemented using resistor-capacitor (RC), inductor-capacitor (LC), or operational amplifier circuits.
The cutoff frequency determines the transition point, where frequencies below it pass through an LPF and are attenuated in an HPF, while the opposite happens in an HPF. LPFs are often used in audio equalization and signal smoothing, whereas HPFs are useful in removing DC offset and edge detection in image processing.
