What is the functio...
[Solved] What is the function of a flyback diode in relay circuits?
4 Users
2 Reactions
Hi everyone,
I'm a bit unclear on the role of the diode in relay circuits. I understand that the diode helps protect the circuit from voltage spikes when the relay is turned off, but is it really necessary to include a diode across the relay coil in all cases?
Can the relay function properly without one, or are there specific situations where the diode is essential to prevent damage to the control circuit?"
2
A flyback diode (also known as a freewheeling diode or snubber diode) is used in relay circuits to protect other components in the circuit from high-voltage spikes that are generated when the relay coil is de-energized.
How it works:
When the relay coil is turned off (i.e., the current is interrupted), the magnetic field around the coil collapses rapidly. This collapsing magnetic field induces a high voltage (also called a back EMF or counter-electromotive force) across the coil. If no protection is present, this high voltage spike can damage sensitive components such as transistors, microcontrollers, or even the relay driver circuitry.
Role of the Flyback Diode:
The flyback diode is connected across the relay coil, with its cathode connected to the positive side of the coil and its anode connected to the negative side. When the relay is energized, the diode is reverse-biased and does not conduct. When the relay is turned off and the voltage spike occurs, the diode becomes forward-biased, providing a safe path for the current generated by the inductive kickback. This allows the current to dissipate through the coil and diode in a controlled manner, preventing damage to the circuit.
Key points:
1. Protects sensitive components: Prevents high-voltage spikes from damaging transistors or other components.
2. Improves reliability: Increases the longevity and stability of the circuit by controlling inductive kickback.
3. Simple and cost-effective: A small, inexpensive diode is typically sufficient to protect the circuit.
Without a flyback diode, the high voltage from the collapsing magnetic field could cause arcing or damage to the relay driver or the control circuitry, leading to malfunction or failure of the circuit.
Admin Admin 03/01/2025 5:15 am
@avaq One thing I’ve learned from experience is how often beginners overlook the importance of a flyback diode until they encounter issues like fried transistors or glitchy microcontrollers. It’s such a simple and cost-effective solution, but it can save a lot of time and frustration.
A quick addition for anyone new to this: Always check the current and voltage ratings of the relay and choose a diode that can handle them. Common choices like 1N4007 work for most small relays, but larger relays might need something more robust.
AVAQ AVAQ 06/01/2025 5:57 am
Great addition and summary!
Deboojit Topic starter 08/01/2025 5:57 am
@avaq Thank you for the detailed explanation. This clarifies a lot about the role of the flyback diode in protecting the circuit. I appreciate the breakdown of how it works and its benefits.
Would you say there are any specific cases where the diode might not be necessary, like with certain types of relays or driver circuits designed to handle the voltage spikes? Also, do you have any recommendations for commonly used diodes in such circuits (e.g., 1N4007 or others)?
Thanks again for such a thorough response.
A diode across a relay coil is necessary to protect the control circuit from voltage spikes caused by the collapsing magnetic field when the relay is turned off. This spike, also known as back-EMF, can damage sensitive components like transistors or microcontroller outputs.
In most cases, including the diode (a flyback or freewheeling diode) is essential, especially in low-voltage control circuits. The diode provides a safe path for the current, dissipating the energy harmlessly.
However, in some situations, such as when the relay is controlled by a robust circuit or a mechanical switch, the diode might not be strictly necessary. Additionally, if the circuit already includes another protection mechanism, like a TVS diode or RC snubber, the standard flyback diode might be omitted. That said, including the diode is generally a good practice to ensure circuit longevity and reliability.
