STM32 vs Arduino: Which One is Better?
6 Users
3 Reactions
1
Hi all,
I’ve been using Arduino for a while, but recently I heard that STM32 microcontrollers are more powerful than Arduino boards. Now I’m a bit confused about whether I should switch to STM32 or upgrade to other Arduino boards. Can anyone explain the key differences between them to help me choose the best option for my projects?
thank you
Admin Admin 02/10/2024 4:45 am
@catelectronics It depends. Can you explain the project or application for which you will use the microcontroller?
2
The difference between STM32 and Arduino boards is clear as day but still, I will try my best to explain in detail(yes, I use both)
1. Performance and Power
Arduino boards like the Uno and Mega typically use 8-bit microcontrollers (ATmega328P, ATmega2560) with lower clock speeds (16 MHz).
STM32 microcontrollers use 32-bit ARM Cortex processors with much higher clock speeds (ranging from 48 MHz to 216 MHz or more), giving them significantly better performance for complex calculations and multitasking.
When to choose STM32: If you need higher processing power for tasks like advanced signal processing, real-time data handling, or running complex algorithms.
When to choose Arduino: If your project is simple and doesn’t require high performance, sticking with an Arduino board might be easier and more straightforward.
2. Ease of Use and Programming
Arduino IDE is known for its simplicity, making it a great choice for beginners. The community and libraries are vast, so you can easily find help and ready-made code.
STM32 typically requires using the STM32CubeIDE or tools like PlatformIO, which can have a steeper learning curve. However, STM32 boards are supported by the Arduino IDE as well, so you can still use familiar code but may need to install additional libraries.
When to choose Arduino: If you prefer simplicity and ease of use, especially if you’re already familiar with the Arduino ecosystem.
When to choose STM32: If you’re comfortable with more advanced development environments or need the extra flexibility for complex tasks.
3. Features and Peripherals
Arduino boards often come with basic features like ADC, PWM, and UART, which are sufficient for most hobby projects.
STM32 microcontrollers typically offer a wider range of peripherals, including multiple UARTs, SPI, I2C, timers, DMA, advanced ADC, and more. They are also known for their low-power modes, making them great for battery-powered projects.
When to choose STM32: If you need multiple communication interfaces, better ADC resolution, or plan to work on power-sensitive projects.
When to choose Arduino: If your project doesn’t require extensive peripherals and you want a straightforward experience.
4. Community and Support
Arduino has a massive community. You’ll find tons of tutorials, libraries, and forums where you can get help.
STM32 has a smaller but growing community. It tends to cater more to experienced users, but there are excellent resources available, including ST’s official documentation and forums.
When to choose Arduino: If you rely heavily on community support and quick solutions.
When to choose STM32: If you’re okay with diving into detailed datasheets and are comfortable solving more technical issues.
5. Cost and Availability
Arduino boards, especially the classic models like Uno and Nano, are generally affordable and widely available.
STM32 boards like the STM32F103 "Blue Pill" are very cost-effective and offer a lot of performance for the price. Higher-end STM32 boards can be more expensive but offer better features.
When to choose STM32: If you’re looking for a cost-effective board with high performance.
When to choose Arduino: If budget isn’t a primary concern, and you want a board that’s easy to find and replace.
To summarize:
Criteria Choose Arduino Choose STM32
Performance Simple, low-power projects High-performance, complex tasks
Ease of Use User-friendly, beginner-friendly More advanced, requires learning curve
Features Basic peripherals, good for small projects Extensive peripherals, advanced features
Community Large, supportive community Smaller, but detailed documentation
Cost Generally affordable and accessible High value for performance, scalable options
If you’re happy with Arduino and your projects are well-supported, don't switch. However, if you feel limited by the performance or features of Arduino boards, exploring STM32 could be a great way to expand your skills and capabilities.
I hope this will help you decide the right one.
I made the jump to STM32 when I started building my own 3D printer controller. Arduino boards just couldn’t keep up with the speed and precision I needed for stepper motor control.
However, beware of the learning curve! It’s not just about switching boards; it’s about switching your whole mindset. You’ll need to read datasheets, configure clock settings, and deal with low-level programming. The power is there, but it comes at the cost of simplicity.
My advice: If you’re comfortable diving deep into hardware-level programming and want to push your projects further, give STM32 a shot. Otherwise, maybe try a more powerful Arduino board first, like the Arduino Due.
I think it really depends on the type of projects you're working on. If you're mainly doing simple LED displays, motor control, or basic IoT projects, Arduino boards are perfect. They’re simple and get the job done without much hassle.
But if you want to dive into audio processing, real-time data acquisition, or anything that requires heavy computation, STM32 is a beast. I switched over when I started working on a DIY oscilloscope project because I needed faster ADC and more memory.
Arduino is excellent for beginners, rapid prototyping, and educational purposes. Its simplicity, massive community support, and easy-to-use libraries make it ideal for getting started with embedded systems. You can quickly connect sensors, write basic logic, and see results — no steep learning curve involved.
STM32, however, is a more powerful and professional-grade platform. It’s widely used in industrial, automotive, and consumer electronics (e.g., car ECUs, VR systems like Oculus, drones, and medical devices). By working with STM32, you gain exposure to ARM Cortex-M cores, which are the backbone of many real-world embedded applications.
