Is it okay to power...
Is it okay to power digital ICs directly from a Li-ion battery, or do I need regulation?
My circuit includes a few digital ICs, and I’m planning to power the whole thing using a single Li-ion battery (nominal 3.7V, full charge around 4.2V).
I’m wondering if it’s safe to power digital ICs directly from the battery, or if I should add a voltage regulator in between. Some of the ICs I’m using are rated for 3.3V or 5V, and I’m not sure how much tolerance they have. Is regulation absolutely necessary in this case, or are there scenarios where a Li-ion can safely power digital components directly? Would love to hear how others approach this.
A single Li-ion cell can swing from about 4.2 V when full to 3.0 V when empty, which is fine for parts designed for that range but dangerous for strict 3.3 V ICs — 4.2 V can exceed their absolute max rating and kill them.
If you’ve got mixed 3.3 V and 5 V logic, use the right regulator (buck or LDO for 3.3 V, boost for 5 V) and add proper decoupling and level shifting.
It keeps your chips safe, your logic stable, and avoids turning your portable project into a post-mortem project.
